Corel Painter lets you modify scripts in different ways. You can edit script instructions in order to change a recorded action sequence. You can also rename and delete scripts.
You can edit a script by opening the Script list, which displays the script as a series of instructions that contain parameters, most of which are editable. You can also edit a script by exporting the script (.txt file) and then opening the file in a text editor. For more information, see Importing and exporting scripts.
In the Scripts panel, click the script that you want to edit from the Scripts library viewer. |
8
In the Edit script dialog box, click Done to save the changes to the script. |
The open script becomes the current script and is displayed in the Scripts library viewer. If you choose another script from the Scripts library viewer, the open script does not change.
You can also edit a script by exporting the script and then opening the script file in a text editor. You can export a script by clicking the Scripts options button
in the Scripts panel, and then choosing Export Script.
In the Scripts panel, choose a script from the Scripts library viewer. |
