Corel Painter Help :
Color management : Embedding color profiles when saving files
You can embed an assigned color profile in a file. However, if you did not assign a color profile to the file, the default color profile is embedded.
The following file formats support color profile embedding:
In the Save As dialog box, use the controls to specify a location and filename. |
From the Format list box (Mac) or the Save As Type list box (Windows), choose one of the following file formats: |
If you do not want to embed the color profile, you need to disable the Embed Profile check box.
