You can use the Freehand method to adjust colors. This method lets you draw a curve to produce dramatic results. It’s particularly useful for creating posterized or solarized effects.
Freehand method of color correction.
Choose Effects Tonal Control Correct Colors. |
In the Color Correction dialog box, choose Freehand from the list box. |
Red — allows you to adjust only the red curve |
Green — allows you to adjust only the green curve |
Blue — allows you to adjust only the blue curve |
Master — allows you to adjust all color curves at once |
You can clear all corrections so that you can start again by clicking Reset.
