Corel Painter Help :
Image hose : Loading and managing nozzle files
To paint with a custom nozzle file, one that isn’t available in a nozzle library, you need to load it in the application. You can also store custom nozzle files by adding them to a nozzle library.
Choose Window Media Library Panels Nozzles. |
In the Nozzle Libraries panel, click the Nozzles options button , and choose Load Nozzle. |
4
In the Item Width and Height boxes in the Nozzle Definition dialog box, enter the values you set in the nozzle file. These values describe the grid cell size. |
If you are not sure about these values, first open the nozzle file, and choose File Get Info. The File Information dialog displays all the information you need. For example, "Image hose 3 by 2 items (height 100, width 100)" indicates that this is a 2-Rank nozzle, with three image elements in Rank 1 (horizontal progression) and two image elements in Rank 2 (vertical progression). Item width and height are 100 pixels each (grid cell size of 100 by 100 pixels). |
5
In the Index Rank box, enter 2 for a 2-Rank nozzle and 3 for 3-Rank nozzle. |
6
In the Rank columns, enter the number of image elements used in each rank of the nozzle file. |
If this is a 2-Rank nozzle file, enter 1 in the Rank 3 column. |
Corel Painter needs the information you enter in the Nozzle Definition dialog box to index images correctly.
4
In the Nozzle Libraries panel, click the Nozzles options button , and choose Add Nozzle to Library. |
5
In the Save Nozzle dialog box, name the nozzle. |
In the Nozzle Libraries panel, click the Nozzles options button , and choose Check Out Nozzle. |
In the Check Out Nozzle dialog box, type a value in the Scale box. |
6
Choose File Save As, and save the file to the folder you want. |
7
8
In the Nozzle Libraries panel, click the Nozzles options button , and choose Load Nozzle, and select the nozzle you just saved. |
