| • | To specify performance preferences |
To ensure the optimal performance of scratch disks, consider the following:
| • | Choose a drive that does not contain the files that you are currently working on. |
| • | Choose a different drive than the one used by the operating system’s virtual memory. |
| • | Defragment the scratch disk drive on a regular basis. |
The performance preferences are described in the following table.
Allows Corel Painter to detect and use your Mac system’s additional memory to improve speed and performance. To enable the Mac Memory Extender, your system must have more than 4 GB of available RAM and you must also allocate more than 4 GB of the available memory to Corel Painter (by adjusting the Memory Usage slider).
The number of Undo levels applies across all open documents. For example, if you set 5 undo levels and have two open documents, undoing three operations on the first document leaves you with only two undo operations on the second document.
| • | Do one of the following: |
| • | (Mac OS) Choose Corel Painter X3 menu |
| • | (Windows) Choose Edit |
