Corel Painter Help :
Web : Working with posterize using color set
You can use the Posterize Using Color Set option to force your image to use the default color set. Posterize Using Color Set can help make colors in your resulting image ready for delivery to the web — without a lot of dithering or shifting of colors.
Posterizing means adjusting the number of color levels an image contains. Corel Painter can automatically constrain all the colors in your image to a web-safe, 216-color palette. Although the Posterize Using Color Set option is not designed to be a highly sophisticated method of reducing color (it offers you no control over exactly how color reduction is performed), Posterize Using Color Set can be a real time-saver.
In addition, you can constrain the colors you use to the default or another Corel Painter web-safe palette, utilize new web-safe single color brushes and keep the number of colors in your image to a minimum.
It’s important to note that exporting to GIF format can compromise the color set values used when Posterize Using Color Set has been performed. For best results in those cases:
Select Effects Tonal Control Posterize Using Color Set. |
