| • | To change Cloning preferences |
The Cloning preferences let you customize the cloning and Quick Clone behavior. For example, you can choose to always use the last selected cloner brush variant or automatically open the Clone Source panel. For more information, see Using Quick Clone.
Displays the Clone Source panel automatically when Quick Clone is used.
Turn on Tracing Paper
Activates Tracing Paper.
Activates the last Cloner brush variant.
To enable the Clone Color check box, you must disable the Switch to cloner brushes check box.
Displays a dialog box every time you switch to the Source Image window from the clone document window. The dialog box warns you that any source image editing needs to be updated, saved, exported, or discarded.
| • | Do one of the following: |
| • | (Mac OS) Choose Corel Painter X3 |
| • | (Windows) Choose Edit |
