• | To add a Mixer color swatch to a color set |
• | To create a color set from the Mixer Pad |
You can add individual colors that you saved as color swatches to the currently selected color set. For example, if you mixed colors that you are particularly happy with, you can save them to a color set. You can also create a color set from the colors on the Mixer pad. You can also choose the maximum number of colors that you want to retain from the Mixer pad. For more information, see Working with color sets.
1 | In the Mixer panel, click the Sample Color tool , and choose the Mixer swatch that you want to save to a color set. |
2 | Click the Mixer options button , and choose Add Swatch to Color Set. |
The selected color is added to the current color set. |
1 | In the Mixer panel, click the Mixer options button , and choose New Color Set from Mixer Pad. |
2 | In the New Colorset dialog box, type a name in the Name text box. |
3 | Adjust the Max Colors slider to set the maximum number of colors that you want to add to the color set. |
4 | Click Ok. |
5 | To access the new colors, choose Window Color Panels Color Sets. |
