Corel Painter Help :
Web : Creating server-side image maps
In Corel Painter, you can define a layer as a clickable region. Corel Painter saves this image map information within a separate text file, which you can upload to your web server. It can then be accessed by a CGI script.
Because server-side image mapping is becoming obsolete, be sure to read the previous section on client-side image mapping support.
In the Layers panel, select a layer in the Layer list. |
4
In the Layer Attributes dialog box, specify a name for the layer. |
6
In the URL box, specify a URL to associate with this portion of your image, for example, http://www.corel.com. |
7
Click OK to return to the image. |
The RIFF format contains data about your image that is lost when you convert it to GIF or JPEG. If you want to edit the file later, save a RIFF copy before you generate a GIF or JPEG version.
