Corel Painter Help :
Image hose : Adjusting the size and spacing of image hose elements
You can scale the size of image elements that are applied by the Image hose. At 100%, the images are the same size as they are in the nozzle file.
You can also control the space between images.
The Spacing slider controls the spacing of the images. Settings shown are 85% (left) and 20% (right).
Because spacing is based on the diameter of the brush, the Size settings also affect image spacing. For example, increasing the brush size adds space between the images applied with the hose.
The Min Size slider also affects the size of images applied by the Image hose. When set to stylus pressure or direction, the Min Size setting determines the range in which the images you apply will vary in size. For more information, see Spacing controls and Size controls.
You can also randomize the proximity of images to the stroke path by increasing jitter.
Choose Window Media Library Panels Nozzles. |
In the Nozzle Libraries panel, click the Nozzle options button , and choose Set Nozzle Scale. |
You can also resize the scale of the elements by adjusting the Size slider on the property bar, just as you would with other brushes.
Choose Window Brush Control Panels Spacing. |
