When creating a mosaic from scratch, you can adjust the tile color by adjusting the value, hue, or randomize color variability to build visual interest. You can adjust the color for individual tiles or for larger areas across the mosaic. The tile color is determined by the main color selected in the Colors panel.
If you’re creating a mosaic from a clone source, the tiles are based on the clone source colors. For more information, see To create a mosaic from a clone source.
Normally, each tile is given a single color. If you want more options for coloring tiles, render the tiles to a channel. You can then convert the channel to a selection to paint directly on the tiles, apply effects, or fill them with a pattern, weave, gradient, or image. For more information, see Creating 3D tiles.
In a mosaic, any area that is not covered by tiles is considered grout. A default grout color is assigned to the mosaic background when you begin working, but you can change the color.
Choose Effects Esoterica Make Mosaic. |
In the Make Mosaic dialog box, click the Select Tiles button . |
C (Color) — changes the tiles to the current main color |
T (Tint) — applies a small amount (10%) of the current main color. Repeat to accentuate. |
V (Vary) — adds color variability, based the settings in Brush Controls Panels Color Variability |
In the Make Mosaic dialog box, click the Change Tile Color button . |
Color — changes the tiles to the current main color |
Darken — applies a small amount of black |
Lighten — applies a small amount of white |
Tint — applies a small amount (10%) of the current main color |
Vary — adds color variability based on the settings in Brush Controls Panels Color Variability. |
Choose Window Brush Control Panels Color Variability. |
If the Color Variability panel is not expanded, double-click the panel tab. |
If the Color Variability panel is not open, you must first close the Make Mosaic dialog box, display the Color Variability panel, and then reopen the Make Mosaic dialog box.
In the Make Mosaic dialog box, click the Grout color chip. |
Changing the grout color automatically re-renders the mosaic, which erases any part of the image that is not a tile or grout.
