| • | To access the Help |
| • | To use the Help |
| • | To access a PDF version of the Help |
The following table describes the conventions used in the Help.
Hold down Command (Mac OS) or Ctrl (Windows).
Command + I (Mac OS) or Ctrl + I (Windows)
(For the Mac OS, press Command + I; for Windows, press Ctrl + I.)
Menu commands (Choose X menu
Choose File
By clicking and holding down the Layer Adjuster tool in the toolbox, you can display a flyout that includes the Transform tool.
| • | Choose Help |
| To use the Help |
| 1 | Choose Help |
| 2 | Perform a task from the following table. |
Click the Contents tab, and click a topic in the left pane.
Click the Index tab, and scroll through the entries to find a topic.
(Mac OS) Type a word or phrase in the Search box in the upper-right corner of the Help window, and press Return.
(Windows) Click the Search tab, type a word or phrase in the box, and click Go. Note that the search feature does not support quotation marks. If you enclose the word or expression in quotation marks, the search will not produce any results.
| • | Choose Help |
