In Corel Painter, you have the option of painting directly on the canvas by applying brushstrokes or by creating a layer and applying brushstrokes on it. Working with layers allows you to protect the canvas from any unwanted changes. When you select a layer in the Layers panel, that layer becomes the target for your brushstrokes. For more information, see Getting started with layers.
The result of any brushstroke you make depends on the following:
| • | The brush category (or drawing tool) you choose |
| • | The brush variant you select within the brush category |
| • | The brush controls you set, such as brush size, opacity, and the amount of color penetrating paper texture |
| • | The paper texture |
| • | The color, gradient, or pattern you use as media |
| • | The brush method |
If you are using a Watercolor brush, you can paint only on a Watercolor layer. If you are using a Liquid Ink brush, you can paint only on a Liquid Ink layer. For more information, refer to Working with the Watercolor layer and Working with Liquid Ink brushes.
You can also select a channel or a layer mask as the target for your brushstrokes. For more information, see Creating and copying channels or Creating and deleting layer masks.
When you have an active selection, painting is confined to the selection by default. For more information, see Selections and Transformations.
