Corel Painter 12.2 Update supports Corel Cinco for Painter, which is a companion app that lets you control Painter remotely from your iPad by opening and using any custom palettes that you created in Corel Painter. You can download Corel Cinco for Painter from the Apple App Store.
Corel Cinco for Painter lets you display only one custom palette at a time, but you can quickly switch between palettes. Corel Cinco for Painter displays five palette controls per screen. If your custom palette includes more than five controls, you can swipe the screen to display the additional controls.
The icons of the controls are conveniently positioned to match the shape of your hand so that each finger can quickly tap a control.
Working with Corel Cinco for Painter allows you to extend your workspace and reduce onscreen clutter. It can also replace traditional shortcut keys.
To allow Corel Cinco for Painter to connect with Corel Painter, you need to enable the option in the Painter Preferences dialog box.
To allow Corel Cinco for Painter to connect with Corel Painter |
1 |
Do one of the following:
(Mac OS) Choose Corel Painter 12 menu Preferences Connections.
(Windows) Choose Edit Preferences Connections.
2 |
Enable the Allow Companion Application to Connect to Painter check box.
3 |
Type a name in the Service Name box to give your copy of Corel Painter a unique
name.
You can also specify an Authentication Code to ensure that only a legitimate
user can access your copy of Corel Painter from a remote application.
