Applying Photo Effects
You can apply different Photo Effects to your images to simulate some traditional photo techniques and processes.
Time Machine
The Time Machine lets you recreate some popular photographic styles from the past. It lets you choose from seven styles, which range from the year 1839 to the 1980s. For information about the Time Machine, see Creating vintage-style photos with the Time Machine.
Film and Filters
Corel PaintShop Pro lets you experiment with effects that are inspired by different types of camera film and filters. For information about applying film and filter effects, see Applying film and filter effects to photos.
Black and White Film
You can simulate taking a photo with black-and-white film. To modify the effect, you can apply a wide range of RGB values as well as adjust image brightness and clarity.
Filter color adjustments in the Black and White Film dialog box can create very different results from the original photo (left-most image in top tow).
Infrared Film
You can simulate the look created when you take a photo with black-and-white infrared film and an infrared pass lens filter on the camera. To enhance the effect, you can adjust settings for film grain and flare.
Original photo (left) and the same photo with the Infrared Film effect applied (right)
Sepia Toning
You can simulate the look created when you take a photo with sepia film. Sepia-toned images are similar to black-and-white photos (also known as grayscale photos), except the tones are brown instead of gray.
Selective Focus
You can create a quick miniature effect (also known as a tilt-shift effect) so that the scene in a photo resembles a miniature model or toy. The illusion is created by adjusting the depth of field, usually across a specified horizon line, and increasing the saturation of the photo.
An urban scene (left) appears to be transformed into a miniature model (right).
You can also use Selective Focus to apply a quick depth of field effect to any photo. For general information about depth of field, see Controlling depth of field.
Photo tip: Photos taken from high vantage points usually make the best candidates for a miniature effect.
Vignette
You can fade the edges of a photo to create a vignette effect. You can control the appearance of the edges by choosing a shape and color (light or dark), and adjusting the amount of blur, glow, and feathering.
| To apply the Black and White Film effect |
Edit workspace
1 |
Choose Effects |
The Black and White Film dialog box appears. |
2 |
Modify the settings you want and click OK.
| To apply the Infrared Film effect |
Edit workspace
1 |
Choose Effects |
The Infrared Film dialog box appears. |
2 |
Type or set a value in the Strength control to determine the overall
strength of the Infrared effect.
Higher settings make greens appear brighter and blues appear darker. Setting the value to 0 creates a grayscale image. |
3 |
Type or set a value in the Flare control to apply a halo effect to
lighter areas in the photo.
Higher settings intensify the halation effect, producing soft edges throughout the photo. Lower settings minimize the halation effect. |
4 |
Type or set a value greater than 0 in the Grain control to add a
more realistic infrared graininess to the photo.
5 |
Click OK.
| To apply the Sepia Toning effect |
Edit workspace
1 |
Choose Effects |
The Sepia Toning dialog box appears. |
2 |
Type or set a value in the Amount to age control to determine the
strength of the effect.
Higher settings increase the effect by increasing the amount of brown in the image. |
| To apply a miniature effect by using Selective Focus |
Edit workspace
1 |
Choose Effects |
The Selective Focus dialog box appears. You can maximize the dialog box to increase the size of the Before and After panes of the preview area. |
2 |
In the Area of focus, click one of the following tools:
Planar Selection Tool |
Half Planar Selection Tool |
Radial Selection Tool |
3 |
In the Before pane of the preview area, when your pointer displays
the move cursor |
4 |
Drag the rotation handle (the box at the end of the short line) to
rotate the area of focus.
5 |
Drag a sizing handle (on the solid lines) to set the edges for the
area of focus.
6 |
Fine-tune the results by dragging any of the following sliders:
Blur amount — determines the amount of blur outside the area
of focus
Feather edge — determines the softness of the transition
between the area in focus and the blurred areas. You can also
adjust feathering interactively by dragging a feathering handle
(on the dotted lines) in the Before pane.
Saturation — determines the intensity of the colors in the
photo. Increasing saturation can help simulate the vivid paint
colors used for models and toys.
Interactive elements in the Before pane: (1) Center line (for Planar Selection Tool), (2) Rotation handle, (3) Sizing handle, (4) Feathering handle
You can use the Selective Focus effect to apply a quick depth of
field effect. Adjust the settings to achieve a natural look.
| To apply a Vignette effect |
Edit workspace
1 |
Click Effects |
2 |
In the Area of focus, choose a selection tool and drag in the
Before pane to set the edge for the effect.
3 |
Drag the Dark/Light slider to set an edge color.
4 |
of focus
Diffuse glow — adds a luminescent brightening effect and
softens details in the entire photo
between the area in focus and the edge effect
