Choosing colors from an image or the desktop
You can choose a foreground or background color from any open image, or from any color within Corel PaintShop Pro (such as a color on a toolbar). This feature is useful when you want to use the color of a specific icon, or when you want to match the Windows desktop colors. If you have Windows 2000 or a later version of Windows, you can choose a color from other applications (such as a color displayed in a word processor).
To choose a color from the active image |
Edit workspace
1 |
On the Tools toolbar, choose the Dropper tool ![]() |
2 |
On the Tool Options palette, set the options you want:
Sample Size drop-list — specifies the pixel area for sampling
Use all layers check box — mark this check box to sample from
all image layers
3 |
Click a color in the image to make it the foreground color, or
right-click to make it the background color.
You can also choose a color from the image while using brush
tools, such as the Paint Brush or the Eraser tool, by holding
down Ctrl and clicking in the image to choose a foreground
color or right-clicking to choose a background color.
When the Color Picker is open, you can choose a color from any
open image regardless of the currently selected tool.
To choose a color from the desktop |
Edit workspace
1 |
Make sure that the color you want is displayed on the screen.
2 |
Position your pointer over a color or properties box on the
Materials palette or in a dialog box.
3 |
Hold down Ctrl, and position your pointer over the area of the
desktop that has the color you want.
4 |
Click to select the color.
The selected color appears in the color or properties box that you chose. |
If you want to change the color selection, continue to hold down Ctrl, and click a different part of the desktop. |
When positioned over areas that can be sampled, a small
window follows the pointer and indicates the RGB value of the
color you are sampling.
