Converting text to curves
You can edit vector text by converting it to curves and then adding, deleting, and moving nodes. Nodes are the tiny squares that appear along the object’s outline.
You can convert letters to individual curve objects, or you can convert the entire string of text into one curve object, with each letter as a separate contour within the object path.
| To convert vector text to curves |
Edit workspace
1 |
On the Tool Options palette, choose the Pick tool |
2 |
Select the text.
3 |
Do one of the following:
To convert the entire text object into one vector object, choose
Objects |
To convert each letter to a separate vector object with its own
path, choose Objects |
If you convert each letter to a separate vector object, you must
select the letters individually in order to edit the nodes.
You can edit a curve object by using the Pen tool |
