Copying and moving vector objects
You can copy and move vector objects by using Cut, Copy, and Paste commands. For more information about moving objects precisely, see To move a vector object.
| To copy or move a vector object |
Edit workspace
1 |
On the Tools toolbar, select the Pen tool |
2 |
On the Tool Options palette, click the Edit Mode button |
3 |
Click on a contour, and then double-click one node to select all
nodes.
4 |
Choose Objects |
Copy — copies the selected contour to the Windows clipboard
Cut — removes the selected contour to the Windows clipboard.
If the object has only one contour, the command removes the
entire object.
5 |
Click where you want to copy or move the contour.
6 |
Choose Edit and choose one of the following options:
Paste As New Vector Selection — pastes vector objects within
the same layer
Paste As New Layer — pastes vector objects as a new layer
Paste As New Image — pastes vector objects as a new image
