Correcting photographic perspective
When you take pictures of tall or wide objects, the resulting photographs may have perspective distortion — that is, the objects may seem to be leaning or angled. This distortion occurs when the camera is at an angle to the subject.
By using the Perspective Correction tool, you can fix perspective distortion, such as the angled sides of a building. You can also fix photographic perspective in an entire layer by using the Pick tool.
Using the Perspective Correction tool changes the angle of the building.
| To correct perspective in a photo |
Edit workspace
1 |
On the Tools toolbar, choose the Perspective Correction tool |
A bounding box with corner handles appears on the image. |
2 |
On the Tool Options palette, choose settings for the following
controls:
Grid lines — lets you type or set the number of gridlines to
display
Crop image — recrops the image to a rectangular shape after
the perspective is applied
Marking the Crop image check box deletes the areas of the image that fall outside the rectangle. |
3 |
Drag each handle to the corner of the object that should be
rectangular.
4 |
Click the Apply button |
You can also apply the command by double-clicking the image.
To reset the perspective correction box to the original rectangle,
click Cancel |
| To correct perspective in an image layer |
Edit workspace
1 |
On the Layers palette, select the layer to correct.
2 |
Choose View |
The gridlines help you correct lines in your photograph that should be vertical or horizontal. |
To adjust the grid settings, choose View |
3 |
On the Tools toolbar, choose the Pick tool |
A bounding box appears around the entire layer. |
It may be helpful to expand the image window so that you can see all of the corner handles of the current layer. To expand the image window, drag from a corner or side. |
4 |
Hold down Ctrl, and drag a corner handle on the selected layer.
The image is updated when you finish dragging. Continue adjusting the perspective until the image looks correct. |
If the correction causes some image data to fall outside the
image canvas, you can restore that data by increasing the size
of the canvas. For more information about changing the canvas
size, see Resizing the canvas.
