Creating layouts
You can create a print layout and position images individually, or you can apply the same settings to all of the images.
By rotating and zooming, you can change the print layout of your images. Images are displayed at 100% magnification by default. You can zoom in to get a closer look at image detail, or zoom out to view a larger portion of the image.
When you use a print layout, you can add descriptive text captions, undo or redo the changes you make, and save the layout for future use as a template.
To add images to a layout |
Edit workspace
1 |
Open the image that you want to print.
If you want to select more than one file, hold down Ctrl, and click the files. If the files are in sequential order, click the first file, and then press Shift and click the last file. |
2 |
Choose File ![]() |
Thumbnails of the selected images appear on the left side of the window; the page layout appears in the main workspace. |
If you want to add additional images to the Print Layout window, choose File ![]() |
3 |
Drag the thumbnails into a template cell or onto the custom
layout page.
To position images in a layout |
Edit workspace
1 |
In the Print Layout window, choose a cell.
2 |
Click one of the following buttons:
Fill Template with Image ![]() |
Free Format ![]() |
Size and Center ![]() |
Fill Cell with Image ![]() |
Fit and Center ![]() |
Make Cell Elliptical ![]() |
Make Cell Rectangular ![]() |
You can display the grid if you want to position images with
precision.
To rotate an image in a layout |
Edit workspace
1 |
In the Print Layout window, select an image.
If you want to rotate multiple images, hold down Shift, and select the images. |
2 |
On the toolbar, click one of the following buttons:
Rotate Right ![]() |
Rotate Left ![]() |
To zoom |
Edit workspace
To create a caption |
Edit workspace
1 |
Choose File ![]() |
Thumbnails of the open images appear on the left side of the window; the page layout appears in the print layout workspace. |
2 |
layout page.
3 |
Click the Create a Text Field button ![]() |
4 |
Drag to create the text box.
5 |
In the Text Field dialog box, type the text that you want to appear
on the printed page.
6 |
Set the font, font attribute, and alignment controls.
To continue to use these settings, mark the Retain text settings check box. |
7 |
Click OK.
You can also
Move the text box in the image
Drag the text box.
Size the text box
Drag the corner handles in or out.
Rotate the text
Right-click the text box, and choose Rotate Right or Rotate Left.
To undo or redo a change to a layout |
Edit workspace
Choose Edit ![]() ![]() |
To change the Print Layout workspace |
Edit workspace
1 |
In the Print Layout window, choose View ![]() |
The Print Layout Options dialog box appears. |
2 |
Choose a unit of measurement from the Units drop-list.
3 |
In the Auto Arrange group box, mark one or both of the following
check boxes:
Use borders — creates a border around all images. This option
requires you to set values in the Horizontal border size and
Vertical border size controls.
Stretch to fit — automatically enlarges images to fit, while
maintaining their aspect ratios
4 |
In the Template options group box, do one or both of the
following:
To apply the new default placement option to all cells of the
current template, mark the Apply to current template check box.
To specify the default placement of images in template cells,
choose an option from the Default Placement drop-list.
5 |
In the Grid Settings group box, mark any of the following check
boxes:
Show Grid — displays the grid
Snap-to-Grid — snaps images to the gridlines where you
position them
If you marked the Show Grid check box, you can also mark the Dot Grid check box to use a dotted-line grid. Clear the check box to use a solid-line grid. |
6 |
Click OK.
