Cropping images
You can remove unwanted portions of an image to create stronger compositions or to draw attention to another area of the image. Corel PaintShop Pro helps you crop by providing presets to common image sizes, such as 4 × 6 inches or 10 × 15 centimeters.
Cropping reduces the amount of hard drive memory required for storing the image. In addition, cropping can improve color corrections by eliminating extraneous areas of color. If a photograph requires both cropping and color correction, you should crop the image first and then apply the color correction.
Before printing an image, you can crop it to a specific print size. In addition, you can select an area within the image and then crop the image to the selection borders. You can also create a new image from the cropped area.
You can also rotate the crop rectangle and stretch it outside the bounds of the image. In this case, the crop command resizes the image so that the whole new image fits into the new shape.
You can crop an image based on its opaque (nontransparent) areas. Cropping in this way is useful when you want to eliminate transparent areas at the edges of the image. You can also set the crop area to cover the opaque area of a single layer or of an entire image.
| To crop an image |
Edit workspace
1 |
On the Tools toolbar, choose the Crop tool |
By default, the crop rectangle appears on the image, and the area outside the crop rectangle is shaded. |
2 |
Adjust the crop area size by dragging any of the handles or edges.
To reposition the crop rectangle, place the cursor inside and drag.
You can use a preset crop size by choosing an option from the Presets drop-list on the floating toolbar for the Crop tool, or from the drop-list on the Tool Options palette. |
3 |
When you’re ready to crop the image, click the Apply button |
After cropping an image, you may notice that the Width and
Height values on the Tool Options palette are each set at 0.100.
These settings do not reflect the cropped image size. To see the
image size dimensions after cropping, choose Image |
If you need to, you can stretch the rotated crop rectangle
outside the bounds of the image. The area outside the original
image will be transparent or filled with the background,
depending on which layer you are working on.
| To crop an image for printing |
Edit workspace
1 |
2 |
Define the crop area by dragging within the image.
3 |
On the Tool Options palette, mark the Specify Print Size check box.
If the Specify Print Size check box is marked, the image resolution changes when you change values in the Height and Width controls. The current resolution appears to the right of the Units drop-list. |
4 |
In the Units drop-list, select Inches or Centimeters.
The Pixels option is unavailable for this method of cropping. |
5 |
Type or set position values in the Top, Bottom, Left, and Right
controls.
6 |
Type or set the dimension values in the Height and Width controls.
The final crop area is sized as specified, and the image resolution is reduced or increased as needed. |
7 |
Click the Apply button |
| To crop to a selection in an image |
Edit workspace
1 |
Make a selection in the image.
2 |
Choose Image |
The selection can be any shape. Corel PaintShop Pro positions a
crop area rectangle around irregularly shaped selections.
If you crop to a selection that is feathered, the current
background color fills in the feathered region of the selection.
You can also crop to the selection by choosing the Crop tool |
| To crop to an opaque area in a layer or an image |
Edit workspace
1 |
Click the Crop tool |
2 |
On the Tool Options palette, select one of these options from the
Snap Crop Rectangle To group box:
Layer Opaque |
Merged Opaque |
3 |
Adjust the crop area.
4 |
If any layer has a solid-color (nontransparent) background, the
entire layer or image is selected as the crop area.
Opaque areas that are not rectangular may have transparent
areas remaining after cropping.
| To create a new image by cropping |
Edit workspace
1 |
2 |
3 |
Click the Crop as new image button |
A new image is created, but the cropped image remains unchanged, and remains the active image. |
This feature offers a useful method of creating individual
images from a scan of multiple images. For example, if you scan
four photos in one scanning session, you can use this feature to
quickly separate each photo into an individual image file.
