Customizing brush settings
The Brush Variance palette lets you customize the settings in the Tool Options palette for particular brush options. You can also make random adjustments by increasing the Jitter percentage.
You may find the most benefit to using Brush Variance palette settings if you use a pen tablet or a 4D mouse.
| To customize brush settings |
Edit workspace
1 |
Choose View |
2 |
On the Tools toolbar, choose a brush tool.
3 |
On the Tool Options palette, set the brush options.
4 |
On the Brush Variance palette, set the brush variance for each
option (Color Blend, Hue, Saturation, Lightness, Size, Opacity,
Thickness, Rotation, Density):
Normal — applies no variance
Pressure — applies variance to the selected brush attribute
according to the pressure from a tablet stylus
Tilt Angle — applies variance based on the angle between the
tablet stylus and the tablet
Tilt Direction — applies variance based on the rotation angle of
the brush tip
Orientation — applies variance based on the rotation angle
around the stylus (for 4D mouse only)
Fingerwheel — lets you control the variance in the brush
attribute by using the wheel on an airbrush stylus
Z-Wheel — lets you control the brush attribute by using a 4D
mouse wheel that is set to behave according to the current
application
Direction — controls brush variation based on the angle
between consecutive mouse points on a path
Fade In — fades the brush impression from small to large
Repeating Fade In — repeatedly fades the brush impression
from small to large
Fade Out — fades the brush impression from large to small
Oscillating Fade — repeatedly fades the brush impression in and
out by oscillating between small and large
Options marked with an asterisk (*) in the Brush Variance palette are available only to users with pressure-sensitive tablets. The options available depend on the type of tablet being used. |
5 |
Type or set a value in the Fade rate (pixels) control to select a
threshold for the number of pixels over which the fading in and
fading out occurs.
Lower values produce faster fading; higher values produce slower fading. |
6 |
Type or set a value in the Position Jitter (%) control to select a
percentage for randomly adjusting the brush impression location.
Mark the Scale check box if you want the jitter to scale proportionally when you change the brush size. |
7 |
Type or set a value in the Impressions per step control to indicate
how many brush impressions per step are made of the
brushstroke
To reset brush variance options to their default values, click the
Reset Brush Variance palette button |
If you have a variance loaded with a brush and then load
another brush without loading its variance, the new brush can
take on the variance settings from the previous brush. Click the
You can save your modified brush as a brush tip or as a preset.
For more information about saving brushes and presets, see
Creating brush tips and presets.
