Customizing keyboard shortcuts
You can view existing keyboard shortcuts, assign a keyboard shortcut to menu commands, bound scripts, and tools, and even modify keyboard shortcuts.
| To view the default keyboard shortcut |
Edit workspace
Manage workspace
1 |
Choose Help |
The Help Keyboard dialog box appears. |
2 |
In the Category drop-list, select a category.
Corel PaintShop Pro groups related commands into categories. For example, if you pick the File category, all the commands in the file menu are displayed. To list all commands at once, choose All Commands. |
The commands and their shortcut keys are displayed in the list, sorted by command name. Click any column heading (Command, Keys, or Description) to sort alphabetically by that column. |
You can print the list of the current category of shortcut keys by
clicking the Print |
| To assign a keyboard shortcut |
Edit workspace
1 |
Choose View |
The Customize dialog box appears. |
2 |
Click the Keyboard tab.
3 |
4 |
In the Commands list, select a command name.
The description of the command and any assigned shortcut keys are displayed. |
5 |
Click in the Press New Shortcut Key field.
6 |
Press the new keyboard shortcut you want to assign to the
command.
The shortcut appears in the Press New Shortcut Key field. If the shortcut is already assigned to another command, a message is displayed above the field. |
7 |
Click Assign.
8 |
Assign more shortcut keys, or click Close.
| To modify a keyboard shortcut |
Edit workspace
1 |
Choose View |
2 |
3 |
In the Category drop-list, choose the menu associated with the
command, script, or tool for which you want to modify the
keyboard shortcut.
4 |
In the Commands list, click the item for which you want to modify
the keyboard shortcut.
5 |
In the Current Keys field, click the shortcut.
6 |
Click Remove.
7 |
Click inside the Press New Shortcut Key field so the cursor is
blinking, and press the keyboard keys you want to assign as the
new shortcut.
If the keyboard combination you entered is already assigned, a message is displayed above this field. If the keyboard combination is not assigned, “Assigned to: [Unassigned]” is displayed above the field. |
8 |
Click Assign.
9 |
Click Close.
