Customizing toolbars
When you display the Customize dialog box, the entire Corel PaintShop Pro workspace transforms into customize mode. You can click and drag almost any menu command or tool to any other menu or toolbar. You can add or delete commands from the menus on the Menu bar.
To move a toolbar button |
Edit workspace
With the Customize dialog box displayed, drag the item to
another toolbar.
To add a command button to a toolbar |
Edit workspace
1 |
Choose View Customize.
The Customize dialog box appears. |
2 |
Click the Commands tab.
3 |
From the Categories list, select a category.
Corel PaintShop Pro groups related commands into categories. For example, click the File category to display all File menu commands. To list all Corel PaintShop Pro commands at once, choose All Commands. |
4 |
From the Commands list, drag a command to a toolbar.
To remove a command button from a toolbar |
Edit workspace
1 |
With the Customize dialog box displayed, drag the item to an
empty workspace area or an empty area outside a toolbar.
2 |
Release the mouse button when you see the cursor change to this
shape:.
To reset all toolbars |
Edit workspace
1 |
2 |
Click the Toolbars tab.
3 |
Click Reset All.
All toolbars revert to the default settings. |
You can reset a specific toolbar to its default settings by
choosing it from the Toolbars list and clicking Reset.
You can also open the Customize dialog box by right-clicking
the Menu bar, Tool palette, or Tool Options palette, and
choosing Customize.
You can rearrange a button in relation to the separator by
dragging the button to the desired location.
choosing Customize.
