Duplicating layers
You can duplicate a layer within an image. You can use the duplicated layer as a starting point for a new layer, or you can try out edits and effects on the duplicated layer while keeping the original layer intact. You can also copy a layer to another image.
| To duplicate a layer within an image |
Edit workspace
Select the layer you want to duplicate, and choose Layers |
The duplicated layer is added just above the selected layer. |
You can also right-click the layer name and choose Duplicate.
You can also choose Edit |
| To copy a layer to another image |
Edit workspace
1 |
On the Layers palette, select the layer you want to copy.
2 |
Choose Edit |
3 |
Open the image in which you want to paste the layer.
If the image has layers, click a layer. When the copied layer is pasted, it will appear above the selected layer. |
4 |
Choose Edit |
The layer is pasted on the center of the canvas. |
You can also drag the layer from the Layers palette onto an
open image.
