Editing and saving layouts
Corel PaintShop Pro includes many templates with different layouts that you can use to print your images. The layouts you create can be saved as templates.
You can arrange images in a layout automatically or manually. Before you arrange images automatically, you must choose whether to include borders. If you do not use borders, Corel PaintShop Pro may arrange the images with touching edges. You must also choose whether to size the images to fit the layout. If you do not choose this option, Corel PaintShop Pro keeps them the same size or, if necessary, makes them smaller to fit the layout. Corel PaintShop Pro divides the page into sections of equal size and places each image in a section. Only images on the page or in the workspace are used.
Horizontal and vertical gridlines help you position items evenly on a page. You can display or hide grids and set preferences for grid spacing and appearance. When you display grids, they appear in any image window that is open.
You can snap images to the nearest gridline on the layout.
| To resize an image in print layout |
Edit workspace
1 |
Click the Resize button |
2 |
Choose one of the following options:
Percent of original — resizes an image by a percentage you
specify in the Width or Height boxes
Actual / Print size — resizes an image by the dimensions you
specify in the Width or Height boxes without changing its
aspect ratio
Resizing an image for printing can result in poor image quality.
When you enlarge an image, it loses detail and sharpness. As a
general rule, it is best to avoid enlarging or reducing an image
by more than 25 percent.
You can also resize an image manually by dragging a corner
handle.
| To use borders in a print layout |
Edit workspace
1 |
Choose View |
2 |
Mark the Use Borders check box, and type or set values in the
Horizontal border size and Vertical border size controls.
The default border width is 0.5 inches (1.27 centimeters). |
3 |
Click OK.
If you want to resize images to fit in their cells, mark the Stretch
to fit check box.
As you decide where to move images, you can place them
temporarily in the workspace around the page.
You can also arrange images manually by dragging the image
to a new position on the page.
| To display the grid |
Edit workspace
Choose View |
| To snap images to the layout grid |
Edit workspace
Choose View |
| To change layout grid settings |
Edit workspace
1 |
Choose View |
The Print Layout dialog box appears. |
2 |
In the Grid Settings group box, mark any of the following check
boxes:
Show Grid — displays the grid
Snap-to-Grid — snaps images to the gridlines when you
position them
If you mark the Show Grid check box, you can mark the Dot Grid check box to use a dotted-line grid instead of a solid-line grid. |
| To save a custom layout as a template |
Edit workspace
1 |
Click the Save Template button |
The Save dialog box appears. |
2 |
Enter a name for the new template in the Name field.
If you want to save the image links with the template, mark the Save with Images check box. |
3 |
Click OK.
| To rotate an image in a layout |
Edit workspace
1 |
Select the image.
2 |
Choose Image, and then choose one of the following commands:
Rotate Right
Rotate Left
| To position an image in a layout |
Edit workspace
Drag the image to a new position on the page.
