Editing shapes
You can edit the basic properties of vector objects, such as the line width, line style, and anti-aliasing. You can also rename an object in the Layers palette. You can also hide or display vector objects.
| To modify vector object properties |
Edit workspace
1 |
Select the vector object you want to edit.
If you want to edit multiple objects, choose the Pick tool |
2 |
On the Tool Options palette, click the Properties button |
The Vector Property dialog box appears. |
3 |
Adjust any of the settings.
4 |
Click OK.
| To edit a shape by using the Tool Options palette |
Edit workspace
1 |
On the Tools toolbar, select the Pen tool |
2 |
On the Tool Options palette, click Edit Mode button |
3 |
Click the shape you want to edit.
4 |
Adjust any of the available settings on the Tool Options palette.
Edit mode lets you edit shapes in a variety of ways; however,
you can also edit shapes by using the Pick tool |
