Formatting text
The text formatting options in Corel PaintShop Pro let you control the appearance of text. You can set these options when you create vector, raster, or selection text. If you create vector text, you can reformat the text at any time by changing your text formatting settings. You cannot change the characters or formatting of raster text. You can modify raster text only by using the Pick tool.
You can use the following text options to format your text:
Font, Size, Units, and Font Style — let you choose a typeface, type
size, units based on intended output (print or Web), and type style
(bold, italic, underline, or strikethrough)
Alignment — lets you center multiple lines of text or align them
on a left or right margin
Direction — lets you set the horizontal or vertical direction of the
text
Kerning — lets you change the space between characters
Leading — lets you change the line spacing
Tracking — lets you set equal spacing between characters
Anti-alias — lets you smooth the edges of text characters
You can also change the color of vector text. For information about using the Materials palette to choose colors for the text outline and fill, see Using the Materials palette.
How can you identify vector text?
Vector text, like other vector objects, can be identified by the vector icon
that appears next to the text in the Layers palette.
| To change font attributes |
Edit workspace
1 |
On the Tools toolbar, choose the Text tool |
2 |
Select the vector text characters you want to change by dragging
over them.
You can also select the entire text by pressing Ctrl + A. |
3 |
On the Tool Options palette, perform a task from the following
table, and click the Apply button |
| To change text alignment |
Edit workspace
1 |
2 |
Select the text object you want to align by dragging over it.
3 |
On the Tool Options palette, choose one of the following buttons:
4 |
On the Tool Options palette, click the Apply button |
| To set text direction |
Edit workspace
1 |
2 |
Select the text object you want to reposition by dragging over it.
You can also select the entire block of text by pressing Ctrl + A. |
3 |
On the Tool Options palette, choose one of the following options
from the Direction drop-list:
Horizontal and Down |
Vertical and Left |
Vertical and Right |
4 |
| To change horizontal spacing between characters |
Edit workspace
1 |
2 |
Select the text characters whose spacing you want to change by
dragging over them.
3 |
On the Tool Options palette, type or set a value in the Kerning
control.
Positive values increase the spacing; negative values decrease the spacing. |
4 |
Kerning values are expressed as 1 being equal to one em space
— the width of capital letter M for a given font and font size.
You can use the built-in kerning values for the current font by
marking the Auto Kern check box.
| To change vertical spacing between lines of text |
Edit workspace
1 |
2 |
Select the text lines whose spacing you want to adjust by
dragging over them.
You can also select the entire block or text by pressing Ctrl +A. |
3 |
On the Tool Options palette, type or set a value in the Leading
control.
4 |
| To set equal spacing between characters |
Edit workspace
1 |
2 |
Select the text characters whose spacing you want to adjust by
dragging over them.
3 |
On the Tool Options palette, type or set a value in the Tracking
control.
4 |
| To smooth jagged edges in text |
Edit workspace
1 |
2 |
Select the text object whose edges you want to adjust by dragging
over it.
3 |
On the Tool Options palette, choose an option from the Anti-alias
drop-list:
Off — applies no anti-aliasing (edges appear jagged)
Sharp — applies a slight degree of edge smoothing
Smooth — applies a stronger degree of edge smoothing
4 |
Anti-aliasing may increase the number of colors in an image,
which may cause stray colors to appear along the edges of text.
Anti-aliasing may also make it difficult to reduce the file size
and to maintain image quality.
