Grouping and ungrouping vector objects
You can group several objects or groups of objects to move, resize, reshape, and change their lines and materials.
When you group objects on different layers, Corel PaintShop Pro automatically moves them to the layer of the first object you select. Each group is labeled on the Layers palette and the objects in the group are shown as components.
| To group or ungroup vector objects |
Edit workspace
| To group objects by using the Layers palette |
Edit workspace
1 |
On the Layers palette, click the first object you want to group.
2 |
Hold down Shift, and click each object you want to add to the
group.
3 |
Right-click, and choose Group.
If you group objects from several layers, Corel PaintShop Pro
moves them to the layer of the first object you selected.
Click the plus sign (+) next to the group name to show the
group’s components.
| To remove an object from a group |
Edit workspace
On the Layers palette, drag the object to another group or layer.
