Grouping layers
You can create layer groups to group multiple layers together. Layer groups let you
organize the Layers palette
set layer properties, such as opacity and blend mode, for the
whole group
limit the effect of adjustment and mask layers to the layers
underneath the active layer rather than to the entire image
move all grouped layers together in the stacking order
move linked layers together on the image canvas
delete all layers in the group
Layer groups can contain raster, vector, art media, mask, and adjustment layers and must contain at least one layer. Layer groups can also contain other layer groups, called nested groups. If you move all of the layers out of a layer group, Corel PaintShop Pro deletes the layer group.
For information about viewing layer groups, see To expand or collapse a vector layer or layer group.
| To create a layer group |
Edit workspace
1 |
On the Layers palette, select the first layer you want to include in
the layer group.
2 |
From the drop-list on the toolbar of the Layers palette, choose
New Layer Group.
The layer group is created, and the selected layer becomes part of the layer group. By default, the layer group name contains “Group” plus a number (for example, “Group 1”). |
| To remove a layer from a group |
Edit workspace
Drag the layer to a new position outside the layer group.
You can also remove a layer from a group by choosing Layers |
| To ungroup layers |
Edit workspace
Select the layer group that you want to ungroup, and choose
Layers |
