Importing and sharing brush tips
You can import custom brushes or create your own. For information about creating custom brushes, see Creating brush tips and presets.
After you create a custom brush tip, you can share it with others by sending them the brush file. If the brush uses a custom shape, you must share both the brush file and the custom shape file for that brush.
| To import a custom brush |
Edit workspace
1 |
Choose File |
The Import Custom Brush dialog box appears. |
2 |
Click Open.
3 |
In the Open dialog box, navigate to the brush file that you want to
import, and click Open.
4 |
In the Import Custom Brush dialog box, select the custom brushes
that you want to import, and click Add.
If you want to import multiple brushes, click Add All. |
5 |
Click OK to import the custom brushes.
| To share brush tips |
Edit workspace
1 |
Navigate to ...Documents\Corel PaintShop Pro\14.0\Brushes.
Navigate to the folder in which you saved your custom brushes if it is different from the default Brushes folder. |
2 |
Share the brush files (those with .PspBrush or .PspScript
extensions) — for example, by attaching them to an e-mail
message.
The recipient should save the brush files to ...Documents\Corel PaintShop Pro\14.0\Brushes, or to the folder that contains custom brushes. |
If you are sharing brushes created from selections, you must
share both the PspBrush file and the associated PspScript file.
