Loading masks
When you save a mask to an alpha channel within an image that is saved in PspImage format, you can load that mask from the alpha channel into the same image or into any other image.
The Masks folder of the Corel PaintShop Pro program folder contains sample masks that you can load into images, such as gradients and several types of circles and squares that frame images. Mask files have a .PspMask filename extension.
| To load a mask from an alpha channel |
Edit workspace
1 |
On the Layers palette, choose the layer that you want to mask.
2 |
Choose Layers |
3 |
In the Load from Document drop-list, choose the image that
contains the alpha channel that you want to load. Choose only
open images with existing alpha channels.
4 |
In the drop-list under the document name, choose the alpha
channel that contains the mask.
5 |
In the Orientation group box, choose one of the following
options:
Fit to canvas
Fit to layer
As is
6 |
In the Options group box, choose one of the following options:
Hide all mask — hides pixels surrounding a loaded mask that is
smaller than the current image canvas
Show all mask — shows pixels surrounding a loaded mask that
is smaller than the current image canvas
If you want to invert the transparency of the mask image, mark the Invert transparency check box. |
7 |
Click Load.
The mask layer and the selected layer are added to a new layer group. |
The mask layer applies to the selected layer only. To apply the
mask layer to all underlying layers, drag it from the layer group
to the main level.
| To load a mask from disk |
Edit workspace
1 |
On the Layers palette, click the layer that you want to mask.
2 |
Choose Layers |
3 |
In the Mask group box, click the drop-list to choose from mask
and image files.
The Preview group box displays the selected mask on the image canvas. |
4 |
options:
Fit to canvas — adjusts the mask to fit the current image canvas
(stretching or contracting as needed)
Fit to layer — adjusts the mask to fit the current layer data
(stretching or contracting as needed). If the layer has not been
shifted beyond the edges of the canvas, this option produces
the same results as the Fit to Canvas option.
As is — positions the mask in the upper-left corner of the
current layer. This option does not change the mask
proportions. If the mask image is smaller than the current layer,
Corel PaintShop Pro masks all pixels outside of the mask image
boundaries.
5 |
In the Options group box, choose an option to specify whether
any pixels Corel PaintShop Pro surrounding the loaded mask data
are shown or hidden. These options affect the mask only if the
Orientation option is As Is and the loaded mask is smaller than the
current image canvas.
Invert transparency — inverts the transparency of the mask
Hide all mask — makes surrounding pixels black to hide
underlying pixels
Show all mask — makes surrounding pixels white to show
underlying pixels
Use image value — makes surrounding pixels white or black,
depending on whether the Show All Mask option or the Hide All
Mask option was applied to the original mask.
6 |
Click Load.
Corel PaintShop Pro adds the mask layer and the selected layer
to a new layer group. The mask layer applies to the selected
layer only. To apply the mask layer to all underlying layers, drag
it from the layer group to the main level.
