Merging layers
Merging layers in an image is also referred to as “flattening” an image. You can choose to merge all layers or only selected layers in an image. Merging layers decreases the memory requirements for the image. Layers are merged according to blend modes, vector data and vector text are converted to raster data, and transparent areas of the background layer are replaced with white.
Many file formats, such as JPEG, GIF, and TIF, do not support multilayer images. When you save images to these formats, Corel PaintShop Pro merges all layers into a single background layer. When you save to the PSD (Photoshop) format, the image maintains raster and adjustment layers, but vector layers and art media layers are converted to raster layers.
The following table describes how layer types are merged.
| To merge two layers together |
Edit workspace
1 |
Make sure that one layer is located directly above the other on the
Layers palette.
2 |
Select the top layer.
3 |
Choose Layers |
To merge all layers, choose Layers |
| To merge all visible layers |
Edit workspace
1 |
On the Layers palette, click the Visibility Toggle button |
When the layer is hidden, the Visibility Toggle button changes to |
2 |
Choose Layers |
Invisible layers are not affected. The merged layer, which
maintains the transparency information of the original layers,
appears at the position of the active layer.
If the selected layer is in a group, only the visible layers in that
group are merged. If the layer group is marked as invisible
(making all layers within the group invisible), then none of the
layers within the group are merged.
| To merge all layers in a group |
Edit workspace
1 |
On the Layers palette, select the layer group, or the layer within
the group, that you want to merge.
2 |
Choose Layers |
