Modifying the edges of selections
You can modify the edges of a selection by smoothing its boundary or by adding a border.
| To smooth the boundary of a selection |
Edit workspace
1 |
Choose Selections |
The Smooth Selection dialog box appears. |
2 |
Mark or unmark the following options:
Anti-alias — smooths the edges of the selection
Preserve Corners — preserves the shape of the corners. Unmark
this check box if you want to smooth the corners.
3 |
Specify values for one or both of the following controls:
Smoothing amount — specifies the amount of smoothing to
apply around the selection
Corner scale — specifies the amount of smoothing to apply
around the corners of the selection. This control is not available
when the Preserve Corners check box is not marked.
4 |
Click OK.
You can click the Toggle Selection button |
| To add a border to a selection |
Edit workspace
1 |
Choose Selections |
The Select Selection Borders dialog box appears. |
2 |
Mark one of the following options to set the position of the
feathering:
Inside
Outside
Both
3 |
Type a value in the Border width box.
If you want to smooth the edges of the selection border, mark the Anti-alias check box. |
4 |
Click OK.
