Moving, clipping, and rotating selections
You can move, clip, or rotate a selection. If you want to change the selection area, you can also move the selection marquee.
When you move a selection, you can leave the space empty or you can move a copy of the selection and leave the original unchanged. When you move a selection, it becomes a floating selection. When you perform a new action, Corel PaintShop Pro automatically promotes the floating selection to a new layer.
You can also float a selection, which creates a copy of the selection that you can move or modify without changing the original image. A floating selection temporarily rests above the image or layer on the Layers palette, and an icon indicates that the layer contains a floating selection. After you edit the floating selection, you can defloat it.
You can also move a selection to a separate layer. When you do this, the original selection contents are unchanged, and a copy of the selection becomes the new layer. You can edit this new layer without changing the original image.
After making a selection, you can move the selection anywhere on the image, or off the canvas. If you expand the image window to show the off-canvas gray area, you can see the selection you moved. You can also clip a selection to remove the portion that is not within the image borders.
| To move the selection marquee |
Edit workspace
Using the Selection tool, right-click and drag the selection
marquee to a new position.
You can also move the selection marquee by right-clicking and
dragging with the Move tool |
| To move a selected image area |
Edit workspace
Perform a task from the following table.
| To copy and move a selected image area |
Edit workspace
With the Selection tool active, set the Mode control to Replace,
hold down Alt, and drag the selection.
| To float a selection |
Edit workspace
Choose Selections |
| To defloat a selection |
Edit workspace
Choose Selections |
| To promote a selection to a layer |
Edit workspace
1 |
Create a selection in the image.
2 |
Choose Selections |
The new Promoted Selection appears above the original layer. |
To place a selection as a layer within another image, copy the
selection, open the other image, and choose Edit |
| To clip a selection to the canvas |
Edit workspace
1 |
Move part of the selection off the image canvas.
If necessary, expand the image window to reveal the gray area that appears outside the image borders. |
2 |
Choose Selections |
The selection is defloated, which makes more edit options available. |
3 |
Choose Selections |
The selection area outside the image borders is removed. |
| To rotate a selection |
Edit workspace
1 |
Choose Image |
The Free Rotate dialog box appears. |
2 |
In the Direction group box, choose either Right or Left to specify
the rotation direction.
3 |
In the Degrees group box, set the number of degrees to rotate.
If you want to type a value between 0.01 and 359.99, mark the Free option. |
4 |
Unmark the All layers check box.
5 |
Click OK.
When you rotate a selection, the selection becomes a floating
selection, and the original image remains unchanged.
You can also rotate a selection interactively by using the Pick
tool |
