Processing files in batches
You can process multiple files using the Batch Process feature. Corel PaintShop Pro can make copies of original files, convert them and then save the copies in the output folder you select.
| To convert multiple files to a new format |
Edit workspace
1 |
Choose File |
2 |
Click Browse, and choose the file you want to process from the
Select Files dialog box.
If you want to choose adjacent files, hold down Shift as you click; to choose non-adjacent files, hold down Ctrl as you click. |
3 |
Click Select.
The files you choose appear in the Files to process list in the Batch Process dialog box. |
4 |
In the Save Mode group box, choose an option:
New Type — This is the most basic option, requiring only that a
new output type be set in the Type field of the Save Options
group box. You can also choose to run a script with this option.
This option reads in the file, runs the script (if defined) against
the file, saves the file to its new location and/or name, and
converts it to the new file format.
Copy — This option requires that a script be defined in the
Script group box. This option reads in the file, runs the script
against the file, and saves the file to a new location and/or
name. With this option selected, the Type field and Options
button of the Save Options group box are disabled.
Overwrite — This option requires that a script be defined in the
against the file, and saves the file to its original location (the
original file is overwritten). With this option selected, all Save
Options group box settings are disabled.
5 |
Click Options to open the Save Options dialog box.
Not all file formats have associated options. If the file format you choose does not have any options, the Options button is unavailable. |
6 |
Choose options from the Format and Encoding group boxes.
7 |
Click Start to open the Batch Progress dialog box and start the
batch conversion.
The Current Step pane displays each filename and its conversion status. The Job Progress bar indicates the conversion progress. |
8 |
Click OK.
Unless you specify another output folder, Corel PaintShop Pro saves the converted files in the same folder as the source files. |
| To run a script on multiple files |
Edit workspace
1 |
Choose File |
2 |
Click Browse to open the Select Files dialog box.
3 |
Choose the folder where the files are stored.
4 |
Do one of the following:
To select adjacent files, hold down Shift and click the files.
To select non-adjacent files, hold down Ctrl and click the files.
5 |
Click Select.
The files appear in the Files to process list in the Batch Process dialog box. |
6 |
In the Save Mode group box, choose one of the following options:
New Type — runs the script and saves the processed files as a
new file type. You can choose to save the output files to another
folder by clicking Browse.
Overwrite — runs the script and saves the file to its original
location, overwriting the original file
Save Script — runs the script but does not save the file. Use this
option when the script performs a save on the file.
If you choose Copy, you can rename the converted files by clicking Modify, choosing an option from the Rename Options list, and clicking Add. You can rename the file with the current date or time, a document name, the position of the file in the renaming process, or by custom text. |
If you choose Overwrite, you can clear the Stop on error check box to avoid having to confirm the overwriting of each file. |
7 |
In the Script group box, mark the Use Script check box.
8 |
Choose a script from the drop-list.
9 |
Click Start.
The Batch Progress dialog box opens and the batch conversion starts. The Current Step pane displays each filename and its conversion status. The Job Progress bar indicates the conversion progress. |
10 |
Click OK.
