Removing digital noise
The term “noise” as it relates to photos refers to small specks of color that interfere with image clarity. These specks are usually caused by poor lighting conditions or the limitations of the sensor in your digital camera. For example, when you zoom in on a photo of a clear blue sky, you may see tiny specks of orange, red, purple, green, or other colors.
Corel PaintShop Pro gives you two fast, powerful commands for removing noise from your photos: One Step Noise Removal and Digital Noise Removal. When you use a noise removal command, the program analyzes your photo, identifies the noise artifacts, and applies corrections based on these identified areas, while preserving the important edge details of your photo.
The image on the left looks grainy because of digital camera noise. The image on the right appears smoother and less grainy after the noise has been removed.
You can automatically apply noise correction to your photo with the One Step Noise Removal command. You can also control more precisely how the same corrections are applied by using the more comprehensive Digital Noise Removal command.
The Digital Noise Removal command gives you more control over the removal of digital camera noise in your photos.
Photos taken with the same camera tend to have noise in the same areas. You can create a preset to apply the same corrections to all of these photos.
This command could be an ideal solution in the following scenarios:
For photos that most likely contain excessive noise (such as a video
whiteboard capture), using the command with low settings can
help make the overall image clearer without excessive blurring.
For photos taken with normal settings, this command is best used
only on key areas needing correction, such as image artifacts
surrounding the subject area.
For photos containing areas that you want to exclude from the
noise correction, you can specify the color ranges to preserve or
discard. For example, you may want to protect skin tones in a
photo from having any correction applied to them. You can define
as many of these protected regions as you like.
| To remove digital noise quickly |
Edit workspace
Choose Adjust |
After a brief pause, the noise is automatically removed. |
| To use advanced options for removing digital noise |
Edit workspace
1 |
Choose Adjust |
The Digital Noise Removal dialog box appears. |
The three crosshairs appear on the image preview in the Remove Noise tabbed area. The crosshairs represent noise samples located in the image’s light, midtone, and dark areas. You can move a crosshair by dragging the bounding box in the before pane, which moves the sampling region accordingly. |
2 |
In the Remove Noise tabbed area, mark the Link detail sizes check
box to adjust the Small, Medium, and Large settings in proportion
to each other.
3 |
Type or set values in the Small, Medium, and Large controls.
These controls define the amount of correction to apply to small, medium, and large noise patterns. |
4 |
Type or set a value in the Correction blend control to determine to
what degree the corrected image will be blended in with the
original.
The blending values range from 0.0 (no noise reduction) to 100.0 (full processing of the entire image). The default value is 70. |
5 |
Type or set a value in the Sharpening control to determine the
degree of sharpening, if any, to apply to the image after the noise
reduction is applied.
The default value is 0. |
6 |
Click OK.
You can have a maximum of 10 sampling regions.
You should avoid sampling an image edge, or pure black or
pure white regions of the image, which can result in excessive
smoothing.
The Digital Noise Removal command is not designed to remove
moire patterns. For information about removing moire
patterns, see To remove moire patterns.
To save settings as a preset specific to an image and camera,
mark the Camera preset check box and click the Save Preset
button |
For best results when working with JPEG images, choose Adjust
| To protect image areas from noise corrections |
Edit workspace
1 |
Choose Adjust |
2 |
Click the Protect Image tab.
3 |
In the Before pane, pan and zoom as necessary so that you can
view the region you want to protect.
4 |
Hold down Ctrl, and drag over the region you want to protect.
Holding down Ctrl does not create a corresponding crosshair in the image window of the Remove Noise tabbed area. |
5 |
In the Selected hue range group box, type or set values in the Hue
and Range controls.
The existing settings reflect the area sampled. You can manually adjust the hue knob by dragging it inside the ring. |
6 |
In the Protect selected hue range group box, drag any of the
seven graph handles downward to apply less correction and
smoothing to the corresponding segment of the hue range.
For example, dragging just the middle graph handle to the bottom of the graph completely suppresses the midtone of that hue range. |
The graph handles cannot be dragged laterally. |
7 |
Click OK.
You can remove color adjustments for a selected color range by
clicking Reset Current. To remove all color adjustments, click
Reset All.
