Removing red-eye
Red-eye in photos is a common problem. When light from the camera’s flash reflects off the retina of a photo subject, a red-eye effect is captured in the photo. Corel PaintShop Pro has two methods of removing red-eye from a color photo.
The fastest method of removal is to use the Red Eye tool. A more powerful method is to use the advanced Red Eye Removal command, which lets you change the eye color.
The Red Eye tool replaces the red color in the subject’s pupil with a dark gray color, restoring a natural look.
| To remove red-eye quickly |
Edit workspace
1 |
On the Tools toolbar, choose the Red Eye tool |
2 |
On the Tool Options palette, adjust the Size of Red-Eye control so
that the pointer is about twice the size of the red area needing
correction.
3 |
Position the pointer directly over the eye, and click.
You can zoom in on the photo, if necessary, for better control
of the Red Eye tool.
You can size the pointer interactively by holding down Alt while
dragging the Red Eye tool over the eye area.
| To use advanced options for red-eye removal |
Edit workspace
1 |
Choose Adjust |
2 |
In the After preview area, drag to center the red eyes of the
subject. If necessary, use the Zoom control to see the eyes in more
detail.
3 |
Choose a color variation option from the Hue and Color drop-lists.
The Hue drop-list is available only for the Auto Human Eye method. |
4 |
From the Method drop-list, choose one of the following
correction methods:
Auto Human Eye — automatically selects the correction area
and chooses settings appropriate for a human eye
Auto Animal Eye — automatically selects the correction area
and chooses settings appropriate for an animal eye. This
method lets you rotate the selection.
Freehand Pupil Outline — lets you use the Freehand Selection
tool to select the correction area for human or animal eyes
Point-to-Point Pupil Outline — lets you use the Point-to-Point
Selection tool to select the correction area for human or animal
eyes
When more careful correction is needed, such as for a partially obscured pupil, it is best to use the Freehand Pupil Outline method or the Point-to-Point Pupil Outline method. |
5 |
In the Before preview area, perform one of the following tasks:
For the Auto Human Eye or Auto Animal Eye method, click
inside the red area of the eye to select the eye automatically, or
drag from the center of the eye to the outside edge of the red
area.
For the Freehand Pupil Outline method, drag around the edge
of the red area of the pupil until you reach the beginning point
of the selection.
For the Point-to-Point Pupil Outline method, click around the
edge of the red area of the pupil, and double-click when you
reach the beginning point. You can reverse a click by right-
clicking.
After you select the eye, a circle appears around the selected area, and a control box for making adjustments encloses the circle. The After preview area displays the corrected eye. |
If you choose the Freehand Pupil Outline method or the Point-to-Point Outline method, confine the selection area to the pupil of the eye (the small dark circle at the eye’s center). These methods are designed to correct the pupil area, where red-eye occurs, without changing the surrounding iris. |
6 |
Set the following controls to fine-tune the red-eye correction:
Pupil lightness — specifies the amount of lightness in the pupil
so that the corrected eye matches the natural eye color
Iris size — specifies the size of the iris. Increasing the iris size
decreases the pupil size.
Glint lightness — specifies the lightness of the glint. Lower
values darken the glint; higher values lighten it.
Glint size — specifies the size of the glint
Feather — adjusts the edges of the corrected eye so that they
appear to blend into the surrounding image areas or appear
more defined. Lower values make the edges more defined;
higher values blend the edges into the surrounding image areas.
Blur — blends the eye with surrounding pixels when the photo
has a grainy appearance. You can increase the setting one unit
at a time until the eye blends naturally with the rest of the
image.
7 |
Click OK.
The Refine slider helps you correct red-eye when the eye is
partially obscured in the original photo. For example, if the
eyelid covers part of the eye in the original photo, it should also
cover that part of the eye in the corrected photo. Dragging the
slider to the left reduces the correction and minimizes its
overlap with the surrounding skin.
