Saving and loading selections
You can save complicated selections that you may want to reuse. You can also save selections as files or as alpha channels.
When you save a selection, it is saved as a separate file with a .PspSelection filename extension. When you load a selection into an image, Corel PaintShop Pro creates a selection based on luminance, non-black pixels, or opacity.
Alpha channels in images are data storage areas that hold selections and masks. When you save a selection as an alpha channel, the selection is stored as part of the image on which it was originally created, rather than as a separate file. Selections and masks stored in alpha channels have no effect on the look of an image.
When you save the image in a file format other than the PspImage file format, its alpha channels are not saved. Therefore, it is best to keep a master copy of your image in PspImage format.
When you save a selection to an alpha channel within a PspImage image, you can load that selection from the alpha channel into the same image or into any other image.
If you saved selections to alpha channels that you no longer need, you can delete them. Only alpha channels from the current image can be deleted.
| To save a selection to a file |
Edit workspace
1 |
Choose Selections |
The Selection Files group box displays selection files in ...Documents\Corel PaintShop Pro\14.0\Selections. To change the default folder, or to add another folder, click the File Locations button |
2 |
In the File name box, type a name for the selection.
3 |
Click Save.
| To load a selection file from disk |
Edit workspace
1 |
Choose Selections |
The Load Selection from Disk dialog box appears. |
The Selection group box shows selection files in all folders. To change the default folder for locating selections, click the File Locations button |
2 |
Choose a selection from the Selection drop-list.
3 |
In the Operation group box, choose one of the following options:
Replace selection
Add to current selection
Subtract from current selection
4 |
In the Create Selection From group box, choose one of the
following options:
Source luminance
Any non-zero value
Source opacity
5 |
Click Load.
| To save a selection to an alpha channel |
Edit workspace
1 |
Choose Selections |
The Save Selection to Alpha Channel dialog box appears. |
2 |
Choose an image from the Add to document drop-list in the
Alpha Channels group box.
Any existing alpha channels in the image are shown in the preview box below the drop-list. |
3 |
Click Save.
The selection is saved to the alpha channel. |
| To load a selection from an alpha channel |
Edit workspace
1 |
Choose Selections |
The Load Selection from Alpha Channel dialog box appears. |
If you want to show the area around the selection as either transparent or black, click the Toggle transparency checkerboard button |
2 |
From the Load From Document drop-list, choose the filename of
the image that contains the alpha channel you want to load.
The image must be open in Corel PaintShop Pro for it to appear in the Load From Document drop-list. |
3 |
Replace selection
A message in the Operations group box indicates how the alpha channel intersects the canvas of the current image. |
If the alpha channel does not intersect the image canvas or intersects it only partially, you can move the selection onto the image canvas by marking the Move to upper left check box. |
4 |
In the Options group box, choose one or more of the following
options:
Move to upper left
Clip to canvas
Invert selection
5 |
Click Load.
| To delete an alpha channel |
Edit workspace
1 |
Choose Image |
The Delete Alpha Channel dialog box appears. |
2 |
Choose the alpha channel you want to delete from the drop-list in
the Alpha Channels group box.
If you want to delete all alpha channels, mark the Delete all alpha channels check box. |
3 |
Click Delete.
