Saving images
Before you save an image, you need to consider the file format in which you want to save it, and you must ensure that you don’t overwrite an original image that you may need in the future.
The PspImage file format of Corel PaintShop Pro supports layers, alpha channels, and other features used in creating images. It is recommended that you save and edit your images as PspImage files. You can then save the files to common file formats. You can also use the Save for Office command if you want to optimize your images for placement in another application, such as a page layout, e-mail, or Web page design application.
The following list provides basic information about common file formats:
JPEG — a standard file format for digital photos that is suitable for
e-mail and the Web. It uses lossy compression, which ensures a
small file size but entails a loss of image data each time you save.
For this reason, this format is not recommended for editing
photos unless a high quality setting is used. This file format
supports EXIF and IPTC data, which can be used to provide
information about the photo, such as when a photo was taken.
TIFF — a standard file format for printing and sharing images
between programs. This file format uses non-lossy compression.
Although you do not lose image data when you save the file, the
larger file size is less suitable for e-mail and the Web. TIFF can save
data in the CMYK color mode for printing, and it supports EXIF
and IPTC data.
PNG — a file format widely used for Web images. It uses non-lossy
compression to reduce the file size without losing image data.
RAW camera formats — a file format typically used by
professional photographers. RAW camera formats provide
uncompressed, unprocessed image data and gives you the most
control over how an image is processed. You must have a camera
that captures digital image in a RAW format, and you need
software that lets you open and work with the file, such as
Corel PaintShop Pro.
You can save a PspImage file with or without compression. Both compression methods that Corel PaintShop Pro uses are lossless and reduce the file size without losing any image information. Uncompressed files require more disk space.
Corel PaintShop Pro uses the following compression methods:
Run length encoding (RLE) — a fast compression method, which
compresses most multilayer images to about 75 percent of their
original size. This method works well with images that contain
large areas of the same color.
LZ77 compression — a slower compression method that
compresses most images to smaller sizes than with the RLE
method. This method works well with photorealistic images.
When you save a new image, Corel PaintShop Pro lets you select its location, name, and file format. When you save an image and then edit it, the image title bar displays an asterisk, or modifier tag, after the filename to indicate that the file has been modified. This tag disappears each time you save your work.
You can also automatically save your files at specific intervals to avoid losing your work if your computer shuts down unexpectedly. For more information, see Setting Autosave preferences.
If you want to save a version of a file, you can save a copy of an image. This is useful when you want to apply effects to an image but keep the original file.
| To save a new image |
Edit workspace
1 |
Choose File |
The Save As dialog box appears. |
2 |
From the Save in drop-list, choose the folder in which you want to
save the file.
3 |
In the File name field, type a name for the file.
4 |
In the Save as type drop-list, choose a file format. The most
commonly used formats are listed first.
If you want to change the default settings for the file format (for example compression or color profile), click Options, and choose the settings you want. |
5 |
Click Save.
You can also save your work by clicking the Save As button |
You can save in the last-used file format by choosing File |
| To save your work |
Edit workspace
Choose File |
If the Auto-Preserve Originals preference setting is enabled, and this is the first time you’ve attempted to save changes to this image, you are prompted to save a copy of the original unedited image. If Auto-Preserve Originals is not enabled, the original image is overwritten by the modified image. |
You can avoid overwriting the current file by using the Save As
command.
You can also save your work by clicking the Save button |
| To save a copy of an image |
Edit workspace
1 |
Choose the File |
The Save Copy As dialog box appears. |
2 |
From the Save in drop-list, choose a folder in which to save the
image.
If you want to create a new folder for the image, click the Create New Folder button. |
3 |
In the File name box, type a name for the file.
If you want to save the file in a different format, select the format from the Save as type drop-list. The most commonly used formats are listed first. |
4 |
Click Save.
| To save images for office applications |
Edit workspace
1 |
Choose File |
The Save for Office dialog box appears. |
2 |
image.
If you want to create a new folder for the image, click the Create New Folder button |
3 |
From the Optimize drop-list, choose one of the following:
Desktop Printing — sets the image resolution to 200 dpi. This
option is ideal for when you are working in a general page
layout application and you want high-quality images but not an
overwhelming file size.
Professional Printing — sets the image resolution to 300 dpi.
This option is ideal for when you need the highest image quality.
Screen or e-mail — sets the image resolution to 96 dpi. This
option is ideal for when you want a smaller file size that can be
shared or displayed quickly.
4 |
5 |
Choose a file format from the Save as type drop-list.
6 |
Click Save.
