Setting file format preferences
In the File Format Preferences dialog box you can specify how Corel PaintShop Pro handles images in the following formats:
General — this tab lets you set options for RAW camera images.
Windows Metafile — WMF is the Microsoft Windows native
vector format.
Kodak Photo CD — PCD is used by many photo developers. This
format can provide multiple image resolutions in one file.
Portable Network Graphics — PNG is used for Web graphics. You
can set preferences for opening and saving PNG files.
PostScript — Corel PaintShop Pro can read PostScript files
(including multi-page files) through level 2 and open them as
raster images. When converting, Corel PaintShop Pro can anti-
alias objects and retain transparency information.
RAW Graphics — Corel PaintShop Pro can read and save RAW
graphics image formats. This format (which is not to be confused
with RAW Camera Data images) is commonly used in graphics
images in the scientific and computer gaming industries.
For a full list of supported file formats, see Files supported by Corel PaintShop Pro.
What’s the difference between RAW camera data images and RAW (Graphics) file format images?
RAW camera data images contain unprocessed sensor data captured by high-end digital cameras from Canon, Fuji, Kodak, Minolta, Nikon, Olympus, and Pentax. The data from these images in no way resembles or responds like RAW graphics image data.
RAW graphics images are basic raster data format images with no compression, and may include an optional non-standard header which is not supported by Corel PaintShop Pro. These graphics images are used primarily by game developers and by the scientific community. Game developers use RAW graphics images for custom image texturing, bumpmapping, and shading. The scientific community uses these images for custom application-based image analysis.
Corel PaintShop Pro can create and edit RAW graphics images as well as provide conversion from standard formats (such as TIF, JPEG, or TGA) into the RAW graphics format.
You can correct the tint, or color cast, certain types of lighting may cause. For example, if the photo was shot indoors in fluorescent lighting, and the camera was set for outdoor lighting conditions, the photo may have a green color cast. In this case, you can choose an option that applies correction for a photo taken in fluorescent light.
| To set General image preferences |
Edit workspace
Manage workspace
1 |
Choose File |
The File Format Preferences dialog box appears. |
2 |
Click the General tab.
3 |
Mark the Open RAW images with Camera RAW Lab check box to
automatically display this command dialog box on opening a RAW
camera image.
| To set WMF image preferences |
Edit workspace
Manage workspace
1 |
Choose File |
2 |
Click the Metafile / Import tab.
3 |
In the Load options group box, choose one of the following
options:
Prompt for size and options each time a file is opened —
prompts you to choose settings for each WMF image you open
Use file header information when available — uses the file
header default size. If you open a file without a header, the size
defaults to the values you type in the Default size when file
header is not available group box.
4 |
Click OK.
You can also
Import WMF vector data as objects you can edit with vector tools
Mark the Import vector data check box.
Smooth curved polylines (vector data only)
Mark the Apply smoothing check box.
| To set PCD file format preferences |
Edit workspace
Manage workspace
1 |
Choose File |
2 |
Click the PCD tab.
3 |
Choose one of the following resolution settings:
96 × 64
192 × 128
384 × 256
768 × 512
1536 × 1024
3072 × 2048
6144 × 4096
4 |
Click OK.
You can have Corel PaintShop Pro ask you to pick a resolution
each time you open a PCD file by choosing the Ask when
loading each file option.
| To set PNG preferences |
Edit workspace
Manage workspace
1 |
Choose File |
2 |
Click the PNG tab.
3 |
Choose one of the following options:
Load and Save transparency to/from layer transparency
Load and Save transparency to/from alpha channel
| To set PostScript file import preferences |
Edit workspace
Manage workspace
1 |
Choose File |
2 |
Click the PostScript tab.
3 |
Unmark the Prompt for size and options each time a PostScript file
is opened check box.
4 |
Set or type a value in the Resolution control.
5 |
Choose a page size option from the Page size drop-list.
6 |
Choose an image mode option from the Image mode drop-list.
7 |
Click OK.
By default, if a PostScript file has a bounding box, the program
matches the canvas size to the bounding box.
| To set RAW file preferences |
Edit workspace
Manage workspace
1 |
Choose File |
2 |
Click the RAW (Graphics) tab.
3 |
In the Save options group box, type or set a value in the Header
size control to set the header size of the file.
4 |
In the 24 bit options group box, choose one of the following color
order options:
RGB order
BGR order
5 |
Choose one of the following color order options:
Planar mode — stores the color data in separate 8-bit planes
Interleaved — stores pixels contiguously
You can flip the image upside down by marking the Flip top
and bottom check box.
