Sharpening images
Most digital photos need some level of sharpening because of the softness introduced in the capturing process of digital cameras. Camera movement at the moment of capture can also produce photos in need of sharpening, and digital cameras are more prone than film cameras to producing slightly out-of-focus photos. In most cases, this problem is easy to fix.
Color, tonal, and resizing corrections tend to soften your photo, so it is best to apply any necessary sharpening before you print, share, or archive your photos.
Corel PaintShop Pro provides sharpening commands that improve blurry photos by increasing the contrast of adjacent pixels. The following sharpening commands can be applied to a selection, a layer, or the entire photo:
You can sharpen high-frequency details, such as edges, while
ignoring low-frequency details, such as large structures, gradients,
and background colors.
You can improve image focus and clarity by increasing the
contrast between adjacent pixels, particularly along edges in the
photo.
You can sharpen the mid- to high-contrast edges in the image
without enhancing noise, as is often done with professional color
correction.
| To apply high-frequency sharpening |
Edit workspace
1 |
Choose Adjust |
The High Pass Sharpen dialog box appears. |
2 |
Type or set a value from 0.00 to 250.00 in the Radius control to
specify the distance (radius) within which dissimilar pixels are
sharpened.
Photos with close-up subjects and softer details usually require higher Radius settings; photos with lots of fine detail usually require lower Radius settings. |
3 |
Type or set a value from 0 to 100 in the Strength control to specify
the overall strength of the command.
4 |
In the Blend mode drop-list, choose one of the following options
to determine how the high-frequency sharpened areas are
blended into the original image area:
Overlay — removes the neutral tones in the image and makes
edge details stand out
Hard Light — produces greater contrast than the Overlay option
Soft Light — produces a softer-looking photo
5 |
Click OK.
| To apply minimal sharpening |
Edit workspace
Choose Adjust |
To double the effect, choose the command again.
| To apply moderate sharpening |
Edit workspace
Choose Adjust |
| To apply low-frequency and high-frequency sharpening |
Edit workspace
1 |
Choose Adjust |
The Unsharp Mask dialog box appears. |
2 |
Type or set a value from 0.01 to 100.00 in the Radius control to
sharpened.
3 |
Type or set a value from 1 to 500 in the Strength control to specify
4 |
Type or set a value from 0 to 100 in the Clipping control to specify
the lightness values that adjacent pixels must have in order to be
sharpened.
5 |
Click OK.
