Using custom workspaces
The Corel PaintShop Pro workspace consists of palettes, toolbars, and open images. You may find that the way you arrange the workspace while editing photos may differ from the arrangement while using the Web tools. Fortunately, Corel PaintShop Pro lets you save and use any number of workspace arrangements.
Saving custom workspaces
When you save a workspace, Corel PaintShop Pro saves the information in a PSPWorkspace file. The following information is stored:
ruler, grid, and guide information
menu, palette, and toolbar settings, locations, and docking status
full screen edit mode status
open images, including zoom levels and scroll bar locations
Loading workspaces
You can load a custom workspace. Tool, menu, and palette positions change to reflect the workspace you are loading.
If you had two windows open for the same image when you saved the workspace, they both open again. If an image from the workspace is already open, Corel PaintShop Pro applies the workspace settings to the open image.
Deleting saved workspaces
If you no longer want to use a saved workspace, you can delete it.
| To save the current workspace |
Edit workspace
Manage workspace
1 |
Choose File |
The Save Workspace dialog box appears. |
2 |
In the New Workspace Name field, type a name for the new
workspace.
3 |
Click Save.
If your workspace contains any modified images that you have
not saved, you are prompted to save the changes to your
image. To save the image changes and the workspace, click Yes.
To save the workspace, but not the image changes, click No. To
cancel saving the workspace and the image changes, click
Cancel.
You can open the Save Workspace dialog box by pressing Shift
+ Alt + S.
You can save the workspace in a folder other than the program
default folder, by clicking the File Locations button in the Save
Workspace dialog box. For more information about editing
paths, see Setting file locations.
| To load a workspace |
Edit workspace
Manage workspace
1 |
Choose File |
The Load Workspace dialog box appears. |
2 |
Click one of the following:
Yes — saves the current workspace before loading another one
No — does not save the current workspace before loading
another one
3 |
Select the workspace file you want to load.
4 |
Click Load.
You can open the Load Workspace dialog box by pressing Shift
+ Alt + L..
You can load the workspace from a folder other than the
program default folder, by clicking the File Locations button in
the Load Workspace dialog box. For more information about
editing paths, see Setting file locations.
You can also load a recently used workspace by choosing it
from the list of recent workspaces located at the bottom of the
File |
| To delete a saved workspace |
Edit workspace
Manage workspace
1 |
Choose File |
The Delete Workspace dialog box appears. |
2 |
Select the workspace file you want to delete.
3 |
Click Delete.
You can open the Delete Workspace dialog box by pressing
Shift + Alt + D.
