Using palettes
Corel PaintShop Pro contains many palettes that organize information and commands to help you edit your images. Some palettes appear automatically, others appear when you activate certain tools, and some palettes appear only when you choose to open them. You can easily turn a palette on and off by choosing View
Palettes. Some palettes are available only in specific workspaces.
Palettes display information and may contain both controls and command buttons. Like toolbars, palettes can be moved from their default docked position. For more information about customizing palettes, see Customizing toolbars and palettes.
Palette
Description
Navigation palette
Lets you find and organize photos
Info palette
Displays information about the selected image. It consists of a camera-style display of the settings used to take the photo and a tabbed area that lets you add General information, such as tags and ratings, and access a full list of EXIF or IPTC data.
Learning Center
Displays information about workflow, tools, and commands to help you complete common tasks quickly and efficiently
Organizer
Lets you gather display photos from various folders so that you can select, edit, e-mail, or print them. You can add, remove, and rename custom trays within the palette to match your workflow.
Tool Options
Displays settings and controls for the active tool
Materials
Lets you choose colors and materials for painting, drawing, filling, and retouching
Layers
Lets you view, organize, and adjust settings for image layers
Overview
Displays a thumbnail of the active image; lets you set a zoom level, and displays image information
History
Lists the actions taken on the active image; lets you undo and redo adjacent or nonadjacent actions; and lets you create a Quickscript that can be instantly applied to other open images
Histogram
Displays a graph of the distribution of red, green, blue, grayscale, hue, saturation, and lightness values in an image. You can analyze the distribution of detail in the shadows, midtones, and highlights to help you decide how to make corrections.
Brush Variance
Lets you set additional brush options when you use a paint brush or any other raster painting tool. This palette is particularly useful when you use a pressure-sensitive tablet or a four-dimensional mouse. For example, you can vary the opacity of a brushstroke by applying pressure with the stylus. Some options also work well with a mouse.
Mixer
Lets you place and mix pigments to use with the Oil Brush tool and the Palette Knife tool, allowing you to create realistic strokes with oil paints on Art Media layers
Script Output
Displays a list of your actions and results when you run scripts
| To display or hide a palette |
Edit workspace
Choose View Palettes, and click the palette name.
Palettes that are currently displayed are denoted with a check mark  . |
| To resize a palette |
Edit workspace
Drag the corner or edge of a palette.
You can also resize a docked palette by clicking the Minimize
palette  or Maximize palette  button in the upper-right
corner of the palette’s title bar.
