Using textures
You can paint, draw, or fill with a texture to create the effect of a textured canvas or paper. You can use textures with the current color, gradient, or pattern for foreground and background strokes or fills. Corel PaintShop Pro includes many textures you can choose from, such as clouds, cracked cement, and old paper. You can also create your own textures from an image.
For information about the difference between patterns and textures, see Using patterns.
| To apply the current texture |
Edit workspace
On the Materials palette, click the Texture button |
The most recently chosen texture becomes active. |
| To choose a texture |
Edit workspace
1 |
On the Materials palette, do one of the following:
To choose a foreground texture, click the Foreground and Stroke
Properties box.
To choose a background texture, click the Background and Fill
Properties box.
The Material Properties dialog box appears. |
2 |
Mark the Texture check box.
3 |
Click the Texture drop-list to view thumbnails of the available
patterns and choose a texture.
4 |
Adjust the following controls for the texture:
Angle — specifies the angle (or direction) of the texture, from 0
to 359 degrees
Scale — specifies the scale (from 10 to 250) of the image’s
actual size. At smaller values, the image is repeated more
frequently throughout the texture. At larger values, the image
may be cropped or may lose detail and become blurry.
As you adjust these controls, the Current preview box displays the resulting material (the style plus the texture). |
5 |
Click OK.
You can apply strokes or fills multiple times to gradually darken
and fill in the texture.
You can also change the angle of the texture by dragging the
control needle on the texture in the Material Properties dialog
box.
| To save an image as a texture |
Edit workspace
1 |
Create an image in Corel PaintShop Pro or another application.
2 |
Save the image as a BMP file in the Textures folder of the
Corel PaintShop Pro program folder or in the My Documents/My
PSP Files/Textures folder.
The texture appears in the Texture drop-list in the Material Properties dialog box. |
The Texture drop-list displays all the available files in the
Textures folder of the Corel PaintShop Pro program folder. You
can also include TEX files from previous versions of the
application in this folder.
To change the default location of texture files, click the File
Locations button |
