Tool
Description
 Pan
Lets you control which part of the image is visible in the image window
 Zoom
Zooms in when you click, or zooms out when you right-click. You can drag to define an area for zooming.
 Pick
Moves, rotates, and reshapes raster layers, and selects and modifies vector objects
 Move
Moves a raster layer or a vector layer on the canvas
 Selection
Creates a geometrically shaped selection, such as a rectangle, ellipse, or triangle
 Freehand Selection
Creates an irregularly shaped selection
 Magic Wand
Makes a selection based on pixel values within a specified tolerance level
 Dropper
Lets you choose the foreground/stroke color by clicking or the background/fill color by right-clicking
 Crop
Trims or eliminates unwanted edges
 Straighten
Rotates a crooked photo to straighten it
 Perspective Correction
Squares the perspective of buildings or other objects that appear to be leaning
 Red Eye
Quickly corrects the red-eye effect commonly seen in photos
 Makeover
Provides five modes — Blemish Fixer, Toothbrush, Eye Drop, Suntan, and Thinify — which let you apply cosmetic fixes to subjects in your photos
 Clone
Removes flaws and objects by painting over them with another part of the image
 Scratch Remover
Removes wrinkles, wires, and similar linear flaws from digital photos, and removes scratches from scanned photos
 Object Remover
Covers unwanted elements of a photo with a neighboring texture in the same photo
 Paint Brush
Lets you paint on your image with colors, textures, or gradients
 Airbrush
Simulates painting with an airbrush or spray can
 Lighten/Darken
Lightens areas as you drag, or darkens areas as you drag with the right mouse button. This effect is stronger than the effects produced by the Dodge and Burn tools.
 Dodge
Lets you lighten areas of a photo by clicking or darken areas by right-clicking
 Burn
Lets you darken areas of a photo by clicking, or lighten areas by right-clicking
 Smudge
Smears pixels by picking up new colors as you drag, or pushes pixels by not picking up new colors as you drag with the right mouse button
 Push
Pushes pixels by not picking up new colors as you drag, or smears pixels by picking up new colors as you drag with the right mouse button
 Soften
Softens pixels as you drag, or sharpens pixels as you drag with the right mouse button
 Sharpen
Sharpens pixels as you drag, or softens pixels as you drag with the right mouse button
 Emboss
Creates an embossed effect by suppressing color and tracing edges as you drag
 Saturation Up/Down
Makes colors more vivid as you drag, or less vivid as you drag with the right mouse button
 Hue Up/Down
Shifts pixel hue values up as you drag, or shifts them down as you drag with the right mouse button
 Change to Target
Recolors pixels while retaining detail
 Color Replacer
Replaces the background/fill color with the foreground/stroke color when you click and drag, or replaces the foreground/stroke color with the background/fill color when you right-click and drag
 Eraser
Erases raster layer pixels to transparency
 Background Eraser
Erases around the edges of the areas you want to keep in a photo
 Flood Fill
Fills pixels of a similar tolerance level with the current foreground/stroke material when you click, or with the current background/fill material when you right-click
 Color Changer
Changes the color of an object while preserving the shading and luminosity of the original color
 Picture Tube
Places picture tubes, theme-based artistic elements, in your image
 Text
Places text on your image
 Preset Shape
Adds predefined shapes (such as callouts, arrows, and starbursts) to your image
 Rectangle
Creates a rectangle or square
 Ellipse
Creates an ellipse or circle
 Symmetric Shape
Creates symmetric or star-shaped objects
 Pen
Creates connected or unconnected lines, freehand curves, and Bézier curve segments
 Warp Brush
Shrinks, grows, twists, or distorts pixels
 Mesh Warp
Distorts a photo by dragging points along an overlay grid
 Oil Brush
Simulates oil brushstrokes on an Art Media layer
 Chalk
Simulates drawing with chalk on an Art Media layer
 Pastel
Simulates drawing with pastels on an Art Media layer
 Crayon
Simulates drawing with crayon on an Art Media layer
 Colored Pencil
Simulates drawing with colored pencil on an Art Media layer
 Marker
Simulates drawing with an ink marker on an Art Media layer
 Palette Knife
Simulates applying oil paint with a knife (instead of a brush) on an Art Media layer
 Smear
Smears whatever pigment you’ve applied to an Art Media layer
 Art Eraser
Erases whatever pigment you’ve applied to an Art Media layer
