Displaying masks
A mask overlay is displayed over protected areas to make it easy to differentiate between masked and unmasked areas. The mask overlay is a red-tinted, transparent sheet. If you adjust the transparency of a mask in certain areas, the degree of red displayed by the mask overlay in those areas varies accordingly.
When you paint or modify the mask, the mask overlay shows what is painted or changed.
You can hide or show a mask layer while you edit an image.
| To display or hide the mask overlay |
Edit workspace
On the Layers palette, click the Highlight mask area button |
The button appears highlighted when the overlay is displayed. |
You can also display or hide the mask overlay by choosing
Layers |
| To change the mask overlay color and opacity |
Edit workspace
1 |
On the Layers palette, right-click the mask layer and choose
Properties.
2 |
Click the Overlay tab.
3 |
Click the Overlay color area, and choose a color.
4 |
Drag the Opacity slider to set the level of opacity.
5 |
Click OK.
| To display or hide a mask |
Edit workspace
Click the Visibility Toggle button on the Layers palette.
