Working with nodes
Nodes are square points on line and curve objects. You can change the shape of a line or curve object by dragging one or more of its nodes.
Nodes have zero, one, or two control arms. The length and direction of the control arms determine the shape of the contour at the node. The straight or curved line between two nodes is a line segment. There are four types of nodes: symmetrical, asymmetrical, cusp, and smooth.
You can use symmetrical nodes to create smooth, flowing curves on either side of a node. Any adjustments to one control arm are mirrored by the other.
You can use asymmetrical nodes to obtain a different amount of curve on each side of the node, but keep a smooth flow through the node. You can adjust the length of each control arm, but the not the direction.
You can use cusp nodes to create extreme changes in direction. You can adjust the length and direction of each control arm independently.
You can use smooth nodes to create a smooth transition between straight and curved line segments.
You can select a node to edit, or you can move it. Moving a node alters the shape of a vector object. If an object has more than one contour, you can move all of its nodes. You can also move the path to move the entire object. You can edit the contour of a vector object by adding, merging, or deleting nodes anywhere along a path.
You can merge nodes on a contour while retaining the line segments on each side. The line segments are combined into one line segment between remaining nodes. If the contour is curved at the node, Corel PaintShop Pro attempts to retain the curve.
You can also delete a node to remove the node and the line segments on each side.
To select a node |
Edit workspace
1 |
On the Tools toolbar, select the Pen tool .
2 |
On the Tool Options palette, click Edit Mode button .
3 |
Click a vector object.
The object's nodes appear. |
4 |
Click the node.
The selected node appears with a solid gray fill. |
To view the selected node more easily, click the Visibility icon
on the Layers palette next to the vector object you are working
on. This hides the fill and outline for the object. For more
information about showing and hiding layers, see Viewing
layers.
Start and end nodes are easy to find. The cursor displays
“START” or “END” when you hold it over the node. If the shape
is closed, the cursor displays “CLOSE.”
To move a node |
Edit workspace
1 |
2 |
3 |
Select a node, and then drag it to a new position.
You can constrain a node’s line segments to 45-degree
increments by holding down Shift as you drag.
To add a node on a contour |
Edit workspace
1 |
2 |
On the Tool Options palette, click one of the following buttons:
Edit Mode
Knife Mode
3 |
Click the contour.
4 |
Hold down Ctrl, and click where you want to add a node.
The cursor displays “+ADD.” |
To add a new start or end node |
Edit workspace
1 |
2 |
On the Tool Options palette, click the Drawing Lines and Polylines
button .
3 |
Select the start or end node of the contour.
4 |
Click to add another node.
The contour automatically connects to the new node. |
To merge one or more nodes |
Edit workspace
1 |
2 |
Select the node you want to merge.
If you want to select multiple nodes, hold down Shift and click. |
3 |
Right-click a node, and choose Edit Merge.
To transform nodes |
Edit workspace
1 |
2 |
On the Tool Options palette, click the Edit Mode button .
If you cannot see all of the options on the Tool Options palette, click the More button . |
3 |
Select one or more nodes.
4 |
Choose Objects Transform Selected Nodes, and choose one of
the following commands:
Flip — moves selected nodes along the vertical axis (those on
top go the bottom and vice versa). On a single node, the
command flips the node’s control arms.
Mirror — moves selected nodes along the horizontal axis (those
on the left go to the right and vice versa). On a single node, the
command mirrors the node’s control arms.
Rotate — rotates the selected nodes by the current rotation
setting. Applied to a single node, the control arms (if any) will
rotate.
Skew X — moves selected nodes to the left or right (along the
horizontal axis) using the current skew setting
Skew Y — moves selected nodes to the left or right (along the
vertical axis) using the current skew setting
Contract — moves the selected nodes closer to each other by
the current contraction setting. This command cannot be
applied to a single node.
Expand — moves the selected nodes away from each other by
the current expansion setting. This command cannot be applied
to a single node.
5 |
Where applicable, type a value for the selected transformation
setting.
6 |
Click the Apply button .
To adjust a curve using a node’s control arms |
Edit workspace
1 |
Select a node to display its control arms.
Cusp nodes may have no control arms. |
2 |
Move the cursor over a control handle until the cursor changes to
two rotating arrows.
3 |
Drag the handle.
To constrain the control arms to fixed angles (45-degree
increments), hold down Shift as you drag.
To straighten a curve between two nodes |
Edit workspace
1 |
Select two consecutive nodes.
2 |
Right-click one node, and then choose Node Type Convert to
Line.
To delete a node |
Edit workspace
1 |
Select a node.
2 |
Press Delete.
If you delete a node in the middle of an open contour, the
vector object becomes two separate contours. If you delete a
node in a closed contour, the contour opens.
