Working with swatches
Swatches are styles or materials created from colors, gradients, patterns, or textures that you can save to use again. Swatches offer a way to save your favorite colors, styles, and materials so that you can access them quickly when you are working on projects.
You can select, create, edit, delete, and rename swatches. You can also change the way swatches are displayed.
| To create a swatch |
Edit workspace
1 |
On the Materials palette, click the Swatches tab |
2 |
Click the Create New Swatch button |
3 |
Type a name for the swatch.
This name appears as a tooltip when you hold the pointer over the swatch on the Materials palette. |
4 |
Press Enter.
The Material Properties dialog box appears. |
5 |
Select the style (color, gradient, or pattern) and the texture for the
material.
6 |
Click OK.
You can also click the More Options button |
| To select a swatch |
Edit workspace
1 |
2 |
Do one of the following:
To select a swatch as the foreground material, click the swatch.
To select a swatch as the background material, right-click the
swatch.
| To edit a swatch |
Edit workspace
1 |
2 |
Double-click the swatch you want to edit.
3 |
Edit the style (color, gradient, or pattern) or the texture for the
material.
4 |
Click OK.
You can also click the swatch, click the More Options button
| To delete a swatch |
Edit workspace
1 |
2 |
Click the swatch you want to delete.
3 |
Click the Delete Swatch button |
| To rename a swatch |
Edit workspace
1 |
2 |
Click the swatch you want to rename.
3 |
Click the More Options button |
| To change how swatches are displayed |
Edit workspace
