| • | To split a clip in the Video and Overlay Tracks |
| • | To reposition an Overlay clip |
| • | To resize an Overlay clip |
| • | To specify the alignment and size of the Overlay clip |
| • | To distort the Overlay clip |
| 1 | Click Project as the Play mode and drag the slider to the part you want to cut. |
| 2 | Click the Split Clip button |
| • | Do one of the following: |
| • | Drag the Overlay clip to the desired area on the Preview Window. It is recommended that you keep the Overlay clip within the title safe area. |
| • | In Timeline View, click on the Overlay clip and click Open Options Panel. In the Attribute tab, click Alignment Options and choose from a menu of position options. |
| • | In the Preview Window, drag the handles on the Overlay clip to resize it. |
| Note: If you drag the yellow corner handle, it will keep the aspect ratio when you resize the clip. |
| • | Click Alignment Options in the Attribute tab and click your desired option to achieve your desired effect. |
| This resizes and adjusts the position of the Overlay clip. |
| • | Drag the green nodes at the corners of the outline box that surround the Overlay clip. |
Dragging the green node distorts an overlay clip.
Hold [Shift] while dragging the green nodes to keep the distortion within the outline box of the current clip.
Copyright 2014 Corel Corporation. All rights reserved. Legal Notice
